After "Insert Reply" for Canned Reply Ctrl + Enter doesn't work
(Jan P.) #1
If you used the Canned Replies feature to add some text to you textbox via the “Insert Reply” button the input isn’t active any more and you first have to click the input field before you can use Ctrl + Enter so submit the form and create the post.
(Jeff Atwood) #2
We should retain focus here @sam after insertion, I guess make sure the latest changes to this plugin behave correctly.
(Jeff Atwood) #3
Can you still repro this @jomaxro?
(Jan P.) #4
(On forum.ionicframework.com, a hosted forum afaik, the problem still exists)
(Joshua Rosenfeld) #5
Yes, this still appears to be a #bug.
