Akismet 404 error
I just installed Akismet, tested it and the spam post shows up /review but when I try to go to /admin/plugins/akismet I get a 404. Any thoughts?
Hi David!
That page is not available since it was replaced for the /review page. Are you still seeing the Akismet link in the hamburger menu?
I was wondering if it was related to that, yes I did see it in the hamburger with a notification, but now that I ignored it in /review it is gone
Hmmm you shouldn’t see it in the menu since it’s no longer available. Can you please hard-reload (Ctrl + R) and check if the Akismet link is gone?
I ran the test again, this time no Akismet in the hamburger, weird!
I think that this happens the first time you set up the plugin and it’s because the decision of showing/hiding the link takes place in the browser.
I’ll investigate tomorrow morning and come back here to let you know what I found :slight_smile:
Good finding @davidkingham!
Fixed here:
The decision of showing/hiding the Akismet link is being made based on the reviewable_api_enabled flag, which was only being set if the plugin was enabled (That’s why this came up during set up).
