All users avatars and some of images are gone after rebuilding
I just have installed discourse docker on a subdirectory of my website and I have an ubuntu server after installing I uploaded some images and avatars for users and now all avatars and some of the images are giving 404 error I have followed this documentation.
avatars are now looking like this
some of the images looking like this
Subfolder stuff can be tricky and is a bit less well-tested than a normal configuration.
How old was your site before the upgrade?
It might help to share your app.yml, especially the bits having to do with the subfolder config.
Is it all images, or some images?
just created a website for testing because I have to use this sub-folder discourse in my website that has a lot of traffic so that’s why I tested the documentation before implementing it in my website
only some images but all avatars
##   Subfolder support with Docker   https://meta.discourse.org/t/subfolder-support-with-docker/30507
## discourse-terraform Docker configuration template
## After making changes to this file, you MUST rebuild for any changes
## to take effect in your live Discourse instance:
## this is the all-in-one, standalone Discourse Docker container template
# You may add rate limiting to by commenting out the ratelimited template.
# Out of the box it allows 12 reqs a second per ip, and 100 per minute per ip
# This is configurable by amending the params in this file
templates:
  - "templates/sshd.template.yml"
## which TCP/IP ports should this container expose?
expose:
  - "1357:80" #change this port to port where you want run discourse # fwd host port 80   to container port 80 (http)
  #- "2222:22" # fwd host port 2222 to container port 22 (ssh)
params:
  ## Set db_shared_buffers to 1/3 of the memory you wish to allocate to postgres
  ## on 1GB install set to 128MB on a 4GB instance you may raise to 1GB
  db_shared_buffers: "512MB"
  #version: tests-passed
env:
  LANG: en_US.UTF-8
  ## TODO: How many concurrent web requests are supported?
  ## With 2GB we recommend 3-4 workers, with 1GB only 2
  UNICORN_WORKERS: 3
  ## on initial signup example 'user1@example.com, user2@example.com'
  DISCOURSE_DEVELOPER_EMAILS: "ahmeds.works@gmail.com" #change these emails to site admins emails
  DISCOURSE_RELATIVE_URL_ROOT: /ask
  DISCOURSE_HOSTNAME: "example.com"
  ## TODO: The mailserver this Discourse instance will use
  # change smtp setting to your own smtp setting
  DISCOURSE_SMTP_ADDRESS: smtp-relay.test.com
  DISCOURSE_SMTP_PORT: 587
  DISCOURSE_SMTP_USER_NAME: test@test.com
  DISCOURSE_SMTP_PASSWORD: example
  ## The CDN address for this Discourse instance (configured to pull)
  #DISCOURSE_CDN_URL: //discourse-cdn.example.com
## These containers are stateless, all data is stored in /shared
volumes:
  - volume:
      guest: /shared
  - volume:
      guest: /var/log
## The docker manager plugin allows you to one-click upgrade Discouse
## http://discourse.example.com/admin/docker
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          - mkdir -p plugins
## Remember, this is YAML syntax - you can only have one block with a name
run:
    - exec:
        cd: $home
        cmd:
          - mkdir -p public/ask
          - cd public/ask && ln -s ../uploads && ln -s ../backups
          - rm public/uploads
          - rm public/backups
    - replace:
       global: true
       filename: /etc/nginx/conf.d/discourse.conf
       to: |
          rewrite ^/(.*)$ /ask/$1 break;
          proxy_pass http://discourse;
    - replace:
       to: |
          etag off;
          location /ask {
             rewrite ^/ask/?(.*)$ /$1;
    - replace:
         to: $http_fastly_client_ip
         global: true
    - exec: awk -F\# '{print $1;}' ~/.ssh/authorized_keys | awk 'BEGIN { print "Authorized SSH keys for this container:"; } NF>=2 {print $NF;}'
here’s my Nginx config
server {
        listen 80 ;
        server_name privitevps.ga;
        root /var/www/html/privitevps.ga/;
        index index.html index.htm index.nginx-debian.html index.php;
        location / {
            try_files $uri $uri/ /index.php$is_args$args;
            location ~ \.php$ {
        include snippets/fastcgi-php.conf;
        fastcgi_pass unix:/var/run/php/php7.4-fpm.sock;
        location /ask/ { #your sub directory where you want to run discourse
            proxy_pass      http://localhost:1357/ask; #your local port where discourse is running in my case its running in "1357" than you subdirectory where you want to run discourse
            proxy_read_timeout      90;
            proxy_redirect  http://localhost:1357/ask https://privitevps.ga/ask; #Redirecting proxy from localhost to your domain
@pfaffman my test website
