All words/text have a number beside them after installing plugins
(Glenn Sims) #1
I installed the Babble plugin, Discourse spoilers, and Discourse solved, then rebuilt the app and now my screen looks like this, even after uninstalling them all:
Based on the similarities of some numbers, it looks like a mapping system (the “2d” activity dates have the same number)
Something is definitely wrong here :grimacing:
Another thing with this: in the console after a rebuild, I don’t see the total duration anymore. It usually says something like build: 5m58s before the launcher loads the app
(Jeff Atwood) #2
Most likely Babble as the other plugins are official.
(Glenn Sims) #3
Would there possibly be a way to restore the text?
(maiki) #4
That screenshot does not show what was advertised! I wanted to see numbers next to all words/text. :stuck_out_tongue:
Remove the Babble plugin, first of all. In fact, when you add a plugin, and something breaks, remove that plugin and see if that works. Pro-tip :tm:!
(Daniela) #5
It seems that you have enabled the site setting verbose localization.
(Glenn Sims) #6
You’re right! I guess I don’t know developer mode after all :joy:
Thanks for your help
