Allow all html tags while posting?
plugins
#1
I understand allowing all html tags can be a security risk. But I’m okay with it. I will be moderating each posts and its a small group. I wanted to include few tags like script and iframe etc. I have some experience with docker+javascript+python - With almost no clue about Ruby or Ember templates, writing plugins is beyond my skills at the moment.
Is there a way, where I can disable the removal of html tags by discourse - May be commenting out some section in the code within docker? something like that ? thanks.
(Simon Cossar) #2
I think you will need to use a plugin to do what you want. You can whitelist specific iframes with a very simple plugin. Here is an example:
You can enable specific tags and classes in a similar way:
I think you will have a problem allowing users to use script tags. If your goal is to actually run javascript on the site you could try having your users enter their scripts in codepen http://codepen.io/ and then add the links to their Discourse posts.
#3
thanks the response, will try to figure out a way with above links :smile:
