This guide explains how to allow multiple accounts to register from the same IP address by adjusting site settings or managing the Screened IPs list.
Required user level: Administrator
Discourse uses the max new accounts per registration ip site setting to limit the number of new Trust Level 0 accounts that can be created from a single IP address. The setting has a default value of 3 users.
This limit is bypassed entirely if the IP address already has any Trust Level 2 or higher users, or any staff members, associated with it. It is also bypassed if the IP address has been added to the Screened IPs allowlist (see below).
Increasing the registration limit for all IP addresses
To allow more than 3 users to register from an IP address, you can modify the max new accounts per registration ip site setting according to your requirement.
Allowing specific IP addresses
As an alternative, the Screened IPs list is found at Admin > Security > Logs & Screening > Screened IPs. To allow an IP address, enter it in the New field, select ‘Allow’ from the dropdown menu, and then click the Add button:
You can also use an asterisk wildcard or traditional IP notation (e.g. 123.456.78.9/24) to screen a range of IPs.
Common issues and solutions
Issue: IP address is blocked even after increasing
max new accounts per registration ip.
Solution: Ensure the IP address is not already listed as “Blocked” in the Screened IPs list. If it is, remove it from the list. -
Issue: Spam accounts registering in large numbers after increasing the
max new accounts per registration ipvalue.
Solution: Revert themax new accounts per registration ipto a lower number and use the Screened IPs feature to allowlist only trusted IP addresses.
Check document
Perform check on document:
