Allowing www. on discourse
(Trent) #1
Hey,
Trying to set my prefered domain on google webmasters and it won’t let me select anything until I add the www. version of my site:
Part of the process of setting a preferred domain is to verify that you own http://www.domain.com/. Please verify http://www.domain.com
Is there a setting to allow this? I only need it to verify on webmsters to then change my preffered domain to https:// domain.com/
Thanks
(Michael Downey) #2
example.com and www.example.com are two different host names, so you’d either need to create a new DNS record to point to your existing server, or create a separate web server called www.
Regardless, this is less a matter of Discourse configuration and more of a DNS and/or hosting configuration issue.
(Trent) #3
Hey,
Yeah I figured it out. I forgot to add this eventually took a look and noticed I hadn’t added it. Thanks.
