Alternatives or ETA for static pages
(Justin Gordon) #1
We’re doing great with talksurf.com. Loving discourse!
What would be the best temporary workaround until the proposed static pages feature is available? We simply want a link to a static page, maybe in the header, to show a list of sponsors of the forum.
Static pages plugin
(Jeff Atwood) #2
Why not just create a Discourse topic with the sponsors, and link to that via standard HTML header?
There’s some basic HTML header layout instructions in the “READ ME FIRST: Admin Quick Start Guide” topic.
(Justin Gordon) #3
Thanks. I’m guessing that is what Boing Boing does:
(Sander Datema) #4
You mean that extra header there? Boing Boing uses something like this (CSS section).
(Ian Carroll) #5
If you can mess around with Rails a bit you could add the high_voltage gem which should support adding custom pages (from the command line, not on the web UI). Don’t know if Discourse would interfere with it.
However @codinghorror gave you a much better solution to the problem. Just here for future Googlers.
(Justin Gordon) #6
If we want to create a few static landing pages, maybe with the www subdomain, how would that compare to
And with the above, I probably would make the topic closed, so nobody else could add to the thread.
Any suggestion for adding a couple real static pages on digital ocean? Would I need to install a webserver just to vend 2 static pages?
And yes, I’m they guy behind http://www.railsonmaui.com, so Rails is my specialty. Just not ember.js (yet).
(Ian Carroll) #7
As I said earlier, the high_voltage gem should work fine if you play around with it.
(Justin Gordon) #8
I’m using the docker install, and I’m guessing that I would have to change the git repo source and do my fork in terms of getting updates. Basically, my concern is that it would be a bunch more work to have my own fork of discourse.
(Kane York) #9
Plugins can install gems! Run gem blah inside the plugin.rb just as you would in the Gemfile.
