Amazon SES Problem Mail Sending
(Hakan) #1
Amazon SES i want use.
I verified the site, verified the mail and sent the test mail, sending the test mail from the Amazon panel, no problem
But when I edit my app.yml file with SMTP settings, ./launcher does not send mail from the site after rebuild app.
" [Sender] 554 Message rejected: Email address is not verified. The following identities failed the check in region US-WEST-2 "
I have confirmed my email address, no problem. It does not work after I set SMTP settings
(Cameron:D) #2
https://docs.aws.amazon.com/ses/latest/DeveloperGuide/ses-errors.html
Email address is not verified. The following identities failed the check in region region: identity1, identity2, identity3:
You are trying to send email from an email address or domain that you have not verified with Amazon SES. This error could apply to the “From”, “Source”, “Sender”, or “Return-Path” address.
(Chris Tomlinson) #3
If your account is still in the sandbox mode, you also need to verify the “To” email address (so it can’t practically be used with Discourse until Amazon have removed the sandbox limitations).
