Ampersand & vs. &
This may not be a Discourse problem, please let me know if it’s not.
When we copy/paste information into the posting box, if there’s an ampersand (&), it changes it to & amp; (with no space).
I read in a few other threads (all closed), that this was some sort of safe thing, but what’s happening is that when the sentence is quoted (or copy/pasted to place somewhere else), it comes up as & amp;.
Is there some way to stop having the amp; added?
Again, I’m not a computer person, so I don’t really understand the need for the extra letters.
Thank you for your time and I appreciate all your help.
It is a computer thing
For many, if not most computer languages the ampersand indicates “the string following this up to the semi-colon stands for a single character”.
Unfortunately they can be very tricky at times. The more often it passes through code that interprets it the more likely it will be interpreted in a way not intended.
Guess I’ll just have to delete those extra characters as needed.
Thank you.
It might be related to where you’re copying from. For example, if you’re copying from a more advanced text editor switching to a plain text editor might help. eg. plain Notepad vs. Word
If you are copying with a browser, maybe switching to a different browser that might deal with clipboard content differently might help.
Of course, assuming you can find something that works for you, this would only help with what you copy - paste and you would still need to educate others and do clean up at times.
Try inserting the copied text by pressing Ctrl + Shift + V
That should insert the text without formatting and without changing & into &
