Any option for X posting (cross posting)?
#1
HI
Is there any formal way to X post using discourse from one category to another or would I simply let my users and readers know this topic has been cross posted from over there?
(Robin Ward) #2
Rather than posting the same content in multiple categories we encourage people to use tags. You can add multiple tags to a topic.
#3
How do you mean add tags to a post? I don’t see an option for this?
(Mittineague) #4
You don’t add tags to a post.
You add them to a topic when it’s created, or add them to an existing topic via the topic’s title edit modal.
#5
Yeah but how. I don’t see an option for this. Do I have to change some settings or enable something?
(Mittineague) #6
When you create a topic, the place to add tag(s) is in the text input below the textarea.
For an existing topic, click the edit pencil icon next to the topic title and a modal will open
(Joshua Rosenfeld) #7
Keep in mind you need to enable tagging first. Do so via site settings in /admin.
#8
I dont see that here. I get options to select category and sub category but not tags. Could it be the browser I am using? FF 45.7.0 ? Something is not right.
#9
Will do back in my own forum and check back. But in here, as above I also do not get that option. See image below.
(Joshua Rosenfeld) #10
Tagging may be restricted to TL2 or TL3 and up here…
#11
OK. Thanks.
Do you know if tagging can be manually amended per user?
#12
Ive just checked that is correct.
Must enable tagging in the admin > settings > tags. And then set trust levels.
I’ll have a muck around with this and report back to see if it acts as a solution similar to cross posting.
Thanks
EDIT
It seems to have made a difference but not necessarily the solution I was after. My problem is I run a discount forum so what happens when I have a product that fits into two different categories? Searching via tags is not really easy and once my categories blow out to have heaps of topics if a user is browsing category X for product XA but this product discount is currently only listed in category Y I rely on them finding this by search tool only correct?
(Andy at Focallocal) #13
what about when you only want to cross post, or tag one comment. like 'hey #graphicdesign team can you have a look at this plz" in a webdev thread
i seem to be able to hashtag, but it only shows 3 categories out of the 20 or so we have, so not sure whats up with that
(Rafael dos Santos Silva) #14
This would be better served by mentioning the group graphicdesign, with @graphicdesign. Like we have here with @team.
(Andy at Focallocal) #15
thanks for the reply. that option doesn’t appear to be available to me and i can’t see a guide how to set it up
(Rafael dos Santos Silva) #16
The forum staff should create the group and make it ‘mentionable’ by users.
(Andy at Focallocal) #17
would we have to add each member to a group manually for them to receive a notification? or is there a way to automatically add anyone who posts in the relevant thread?
(Rafael dos Santos Silva) #18
Use one of those settings, on the group page:
(Andy at Focallocal) #19
thanks. so i should be able to give them a direct link to the group to sign up
