API calls not working when login_required
(Tommy Mancino) #1
I am not sure if this is intended behavior or not.
I have implemented SSO, which works great. However, I am unable to make API calls when I make the forum private by checking login_required. If I uncheck it, everything works fine. I have tried it with the master API key, as well as a private API admin key for the signed in user.
I see that I am being redirected to login when trying to access the json via the api, using the discourse-api gem.
ActionView::Template::Error (757: unexpected token at ‘You are being redirected.’):
Is this working as intended? Thanks…
Note: I found this discussion and will look at the source update API to handle CSRF token by spaghetticode · Pull Request #20 · discourse/discourse_api · GitHub
Resolution: This was being caused by the discourse_api gem being out of date. I updated and submitted pull request.
(Sam Saffron) #2
Thanks for the fix. cheers
(Sam Saffron) #3
