API returns err 500 (no +info) when non-convertible unicode is in the body for a new topic
(Dylan Hunt) #1
( Spinned off originally from here for suggestions to provide friendlier API errors : Improve (add) friendly JSON API error messages (at least generic ones) )
Creating a generic new topic:
In “raw”, imagine there being a ¢ or ( ͡° ͜ʖ ͡°) or something with unicode. Attempting to use the API to create a new topic will result in a plain jane 500 err with no extra info –
{"headers":{"Server":"nginx","X-Request-Id":"blah-blah-blah-request-id123","X-Runtime":"0.155158","Connection":"close","Content-Length":"0","Date":"Sat, 07 Oct 2017 14:43:30 GMT","Content-Type":"text/html; charset=utf-8"},"responseXml":null,"responseJson":null,"cookies":[],"responseCode":500,"responseString":""}
Removing the unicode does the trick. The coin above ¢ can be used to test it. Simply adding it gets 500, removing it gets 200.
Nasty little bug ~ this breaks our reporting system, as chat logs often contain unicode. Surely there’s a multitude of other uses for unicode (not just for lenny faces, but for localization)
*It’s important to note that SOME unicode works, such as full-width commas (they are converted to regular-width commas).
(Jeff Atwood) #2
I suspect this has to do with how your request is encoded in the https call?
(Dylan Hunt) #3
This was encoded as a form, following the API docs. I haven’t looked at the docs for a while now, though – did you guys ever switch to application/json or is form still the best?
EDIT: Oh, you are probably talking about UTF-8 or something? Let me check out the default method, I’ll be back. I can’t seem to view or change the default encoding method on GameSparks, so I opened up a ticket:
https://support.gamesparks.net/support/tickets/6460
(Dylan Hunt) #5
Setting the content header as { "Content-Type" : "application/json; charset=utf-8" }; returns error 400 without explanation.
Setting the content-type to just “charset=utf-8” goes back to returning 500 errors. I tried sending as both a form and application/json. I tried many combinations – at this point, I’m more suspecting Discourse than my side - never had an issue with any other site with Unicode, so far.
(Jeff Atwood) #6
Do you see anything on the Discourse side under /logs in your browser?
(Dylan Hunt) #7
Browser console logs (f12)? I couldn’t see anything unique in the console
(Jeff Atwood) #8
Nope under /logs on your Discourse site url
(Dylan Hunt) #9
Interesting - 0 logs for this (I cleared then tried again).
{ “Content-Type” : “application/json; charset=utf-8” };
Returned 500 with no error
{ “Content-Type” : “charset=utf-8” };
Returned 403 with anonymous array response, “BAD CSRF”
Logs show nothing (They had some old stuff, so logs are functional; I cleared it to try it again), but…
  • SHOULD they say something, or does this mean it never delivered?
  • However, if it never delivered, would I actually see a BAD CSRF response? Googling this, it seems to be a Discourse-exclusive response.
  • And shouldn’t it log if I got anything other than 404?
  • Are logs delayed longer than 5m?
(Sam Saffron) #10
Try creating the exact same topic in the browser and look at what chrome sends through, that is the first thing I would try.
(Dylan Hunt) #11
Works fine. I mean I can make or reply or new post directly within right now using symbols like ¢ without an issue. It’s only when using the API.
(Sam Saffron) #12
Thing is, the web app uses the api, inspect the request it makes
(Dylan Hunt) #13
Ah, I can’t see it with F12 – can you recommend the best Chrome extension for viewing Discourse requests?
(Jeff Atwood) #14
Yes you can – did you read the associated howto topic?
@jomaxro does this howto need updating? Can you validate it this week?
(Joshua Rosenfeld) #15
Sure, adding this to my list.
(Joshua Rosenfeld) #16
Looks good to me. Making one minor edit, but it shouldn’t have affected the #howto.
