API usage for site integration
(Marco Perone) #1
I am evaluating Discourse to create a forum for my website, and I would like to know if at the moment it is possible to do the following things through the Discourse API:
  1. add a user to a group
  2. retrieve user notifications
  3. change the user interface language
If these things are possible, can you give me some hint on how to do them?
(Paul Apostolos) #2
I have found that nearly everything I have wanted to do via the API was easy.
I typically take this approach.
  1. Go to the Web interface and look for the setting I am trying to retrieve or change.
  2. Open Fiddler2 or Chrome network tools so I can see all the requests and responses.
  3. Change or retrieve the setting or item.
  4. Review the request/response and replicate that with client code.
We do our integration with RestSharp (.NET REST and HTTP Client).
Here’s a Gist for how we do the add user to group part
(Jeff Atwood) #3
The language can only be set at the server for the entire site. There is no concept at this time of setting language for an individual user.
(Paul Apostolos) #4
@codinghorror what about this site setting?
(Sam Saffron) #7
Just to answer the op here, yes all 3 points are possible using our API if per user locale is enabled
(Sam Saffron) #8
