AppleScript fenced code block broken rendering of # line comments
(Peter N Lewis) #1
The AppleScript fenced code block does not always correctly render # line comments
This fails:
# Create Report on
This works:
# xCreate Report on
This works:
# Create Report o
(Sam Saffron) #2
Not a bug
If you want applescript to work you need to enable it in site settings and restart the app.
Restart hosted version? (and normal restart via admin)
(Peter N Lewis) #3
Huh. Ok. There isn’t any way to restart the app from the Admin panel, is there? Thanks.
(Sam Saffron) #4
nope, you can either run an upgrade from /admin/upgrade or restart the container externally.
