Apt-get autoclean command doesn't work on Mac
(Hidetaka Ko) #1
sudo apt-get autoclean
sudo apt-get autoremove
When I tried to use this command, I encountered this error.
apt-get: command not found
What command should I use for this?
(Matt Palmer) #2
You should use apt-get autoclean. That it isn’t working suggests you aren’t using an Ubuntu machine.
(Hidetaka Ko) #3
I’m using Mac OS. What command should I use instead of apt-get?
(Matt Palmer) #4
What does this have to do with Discourse?
(Hidetaka Ko) #5
Yes. To rebuild discourse app, I tried to use these command like below.
sudo ./launcher rebuild  app
sudo ./launcher cleanup
But, I encountered these errors.
./launcher: line 96: cannot create temp file for here-document: No space left on device
(Jeff Atwood) #6
You need to stick to this topic, before opening new support topics. You’re on a Mac but you aren’t telling people that.
(Robby O'Connor) #7
(Hidetaka Ko) #8
I have storeage on Mac. But, I don’t have storeage on docker and discouse.
(Robby O'Connor) #9
How are you using docker? Docker Machine + Virtualbox? Docker for mac?
(Hidetaka Ko) #10
I’m using Docker for Mac.
(Robby O'Connor) #11
Try: docker system prune
(Robby O'Connor) #12
Also check out the faqs on Docker for mac: Frequently asked questions (FAQ) | Docker Documentation
It tells you how to fix this.
(Hidetaka Ko) #13
I tried like below.
but, I still encounter this error.
(Matt Palmer) #14
You do realise that an EC2 instance is not the same thing as your local Mac, right?
(Hidetaka Ko) #15
Yes. You are right. What should I do on EC2?
(Matt Palmer) #16
  1. Use Ubuntu 16.04, not whatever RHEL-derived AMI you’re using (assumption based on the prompt), because Amazon Linux is nasty, and all our experience and documentation is based on Ubuntu.
  2. Follow the available documentation.
