Archived discussions still allow posts to be deleted
(Ashish Saihgal) #1
Perhaps just a moot point -
Users still have the ability to delete whatever they posted. Does that not change the frozen discussion in a way? One might accidentally delete a vital reply and leave a gap in the discussion.
Should the option to delete replies not be disabled if topic is frozen? I think at the very least it should perhaps be configurable to let forum administrators decide which way they want to go.
(Jeff Atwood) #2
Delete meaning, edit to a new revision that says (removed by author), not actually delete.
Still, you are right, this should not be possible in an archived topic unless you are a moderator @eviltrout.
(Jeff Atwood) #3
Confirmed on try.discourse.org, this is still an issue.
@eviltrout can you add that to your list – unless you are a staff member you should not be able to delete (your own) posts from an archived topic.
(Robin Ward) #4
I’ve fixed this in master, it will go out with our next deploy:
https://github.com/discourse/discourse/commit/8c29ed870e0b9e43204e3af5928bcb4fcfdc2663
(Jeff Atwood) #5
