As admin: can't change usernames
(Codecademy ) #1
I can’t change usernames as an admin. It’s frustrating because there are inappropriate usernames I need to update.
See below I am trying to save it as “sax”
(cpradio) #2
What is the min username length you have set in the Admin > Settings area?
(Codecademy ) #3
Min is 3, max is 20.
(Sam Saffron) #4
Is there anything in /logs ?
(Codecademy ) #5
Uncaught TypeError: this.get(…).querySelectorAll is not a function
Url:
Line: 1
Column: 1697
Window Location: http://discuss.codecademy.com/
OR
Could not find file in the store located at url: //codecademy-discourse.s3.amazonaws.com/original/4X/9/3/c/93c4f882ec404addba7438222cc570e6e5e3b04a.png
(Sam Saffron) #6
Are you running latest Discourse over there ?
Renaming is working fine here so it could be an issue with an earlier release.
(Codecademy ) #7
No we are: 1.5.0.beta6
That may be why? We try to stay on top of updates and I suppose I will prioritoize this one right away.
(Sam Saffron) #8
Possibly, it is either that or an incompatible plugin.
(Tobias Eigen) #9
Are you using SSO? If so, you can’t change usernames via discourse admin.
(Codecademy ) #10
Yes we do have SSO, funny thing is - there is no user under that user name on our site…
(Codecademy ) #11
I updated and still no dice.
See our below plugins:
(Sam Saffron) #12
Do you have the sso overrides username setting set?
