Auto close topic after specific days
Newbie here, is there any way to close a topic after some specific number of days? Or is there any option I need to edit or enable?
Hello!
The first way applies to specific topics only. You must enter a topic as a staff member find the :wrench: icon in the top right of the topic (if you are on mobile it’s bottom right next to topic time line) and select this option. From here through a dropdown menu you can select what to do
The second way is to go into the category settings and configure it from there. Please note this will apply to all topics in that category however this can be changed through the first solution mentioned above.
That helped soo much, thanks @ondrej!
