Auto Update Check is broken?
(Jaimie) #1
I’m getting the following:
A check for updates has not been performed lately. Ensure sidekiq is running.
I did a upgrade on DO 3 days ago as I needed more ram all seemed to be fine.
For that I did the /destroy /bootstrap, etc. Just noticed this message today. Not sure the command or sequence to get this running.
I did see this:
https://meta.discourse.org/t/error-a-check-for-updates-have-not-been-performed/8347?u=puzle&source_topic_id=13363
But that looks before the DO docker stuff.
(Sam Saffron) #2
Pull latest, I just fixed it.
(Jaimie) #3
Thanks and for those reading along the upgrade to 2gb make the web based docker upgrade work without issue. Nice and easy.
(Jeff Atwood) #4
