Automatic Apply Security rules on sub categories (inherit from top)
(Stav Sitnikov) #1
Hi is it possible to configure Automatic Apply Security rules on sub categories (inherit from top) ?
Thanks
(Sam Saffron) #2
Sorry, no we do not implement any kind of inheritance permission wise. You must set permissions manually on every category. Hopefully it is not too much of a hassle, you only need to do so on forum setup.
(Jay Pfaffman) #3
If you need to create so many categories that setting the permissions is arduous, it might be worth using the API to create them. If it’s just a couple dozen, you’d probably rather just suffer through the clicks.
