Automatically set a sub-category to watching
#1
Hello!
I would like to create a private category with one sub-category, and I would like to set by default for all members in the category Watching for the sub-category. Is this possible? Could you explain me how to?
I think this has already been discussed a number of times, but I read many threads and couldn’t find a specific answer, so please direct me to somewhere else if needed
Many thanks!
(Alex Armstrong) #2
Hi Francesca,
I have a plugin that allows you to do this. It’s a bit technical. You will need to fork the code and adjust it to your needs.
Here’s the plugin:
Holler if you need help.
#3
Thanks a lot Alex! Will check this with our techies over here and get back if help is necessary!
