Avatar download issue (WP Discourse)
Hi
I’m having a problem getting Avatars to download for SSO with WordPress. Everything appears to be set up correctly, the SSO from Wordpress is working, the avatar URL is being set correctly. I’ve confirmed that from my production instance I can curl the URL stored in the user profile and get an image file from it. On v1.9.0.beta14 +202
The error I’m getting in logs is:
default: FinalDestination could not resolve URL (invalid URI): https://XXXX/wp-content/uploads/ultimatemember/2/profile_photo.png
backtrace
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/logster-1.2.8/lib/logster/logger.rb:93:in `add_with_opts'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/logster-1.2.8/lib/logster/logger.rb:50:in `add'
/usr/local/lib/ruby/2.4.0/logger.rb:534:in `warn'
/var/www/discourse/lib/final_destination.rb:256:in `public_send'
/var/www/discourse/lib/final_destination.rb:256:in `log'
/var/www/discourse/lib/final_destination.rb:107:in `resolve'
/var/www/discourse/lib/file_helper.rb:42:in `download'
/var/www/discourse/app/models/user_avatar.rb:76:in `import_url_for_user'
/var/www/discourse/app/jobs/regular/download_avatar_from_url.rb:16:in `execute'
/var/www/discourse/app/jobs/base.rb:134:in `block (2 levels) in perform'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rails_multisite-1.1.2/lib/rails_multisite/connection_management.rb:77:in `with_connection'
/var/www/discourse/app/jobs/base.rb:129:in `block in perform'
/var/www/discourse/app/jobs/base.rb:125:in `each'
/var/www/discourse/app/jobs/base.rb:125:in `perform'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/processor.rb:188:in `execute_job'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/processor.rb:170:in `block (2 levels) in process'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/middleware/chain.rb:128:in `block in invoke'
/var/www/discourse/lib/sidekiq/pausable.rb:80:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/middleware/chain.rb:130:in `block in invoke'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/middleware/chain.rb:133:in `invoke'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/processor.rb:169:in `block in process'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/processor.rb:141:in `block (6 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/job_retry.rb:97:in `local'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/processor.rb:140:in `block (5 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq.rb:36:in `block in <module:Sidekiq>'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/processor.rb:136:in `block (4 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/processor.rb:204:in `stats'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/processor.rb:131:in `block (3 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/job_logger.rb:7:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/processor.rb:130:in `block (2 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/job_retry.rb:72:in `global'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/processor.rb:129:in `block in dispatch'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/logging.rb:44:in `with_context'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/logging.rb:38:in `with_job_hash_context'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/processor.rb:128:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/processor.rb:168:in `process'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/processor.rb:85:in `process_one'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/processor.rb:73:in `run'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/util.rb:16:in `watchdog'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/util.rb:25:in `block in safe_thread'
Followed by:
default: FinalDestination did not work for: https://XXXXX/wp-content/uploads/ultimatemember/2/profile_photo.png
backtrace
/usr/local/lib/ruby/2.4.0/logger.rb:543:in `error'
/var/www/discourse/lib/file_helper.rb:8:in `public_send'
/var/www/discourse/lib/file_helper.rb:8:in `log'
/var/www/discourse/lib/file_helper.rb:54:in `download'
I’ve tried from the rails console on production too, I get the same error message when attempting to download the same URL. If I try a URL of a random image found via Google I get a slightly different error:
default: FinalDestination could not resolve URL (status 406): https://XXXXX/data/2016/07/11/589479_admin_256x256.png
backtrace
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/logster-1.2.8/lib/logster/logger.rb:93:in add_with_opts' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/logster-1.2.8/lib/logster/logger.rb:50:inadd’
/usr/local/lib/ruby/2.4.0/logger.rb:534:in warn' /var/www/discourse/lib/final_destination.rb:256:inpublic_send’
/var/www/discourse/lib/final_destination.rb:256:in log' /var/www/discourse/lib/final_destination.rb:182:inresolve’
/var/www/discourse/lib/file_helper.rb:42:in download' /var/www/discourse/app/models/user_avatar.rb:76:inimport_url_for_user’
/var/www/discourse/app/jobs/regular/download_avatar_from_url.rb:16:in execute' /var/www/discourse/app/jobs/base.rb:134:inblock (2 levels) in perform’
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rails_multisite-1.1.2/lib/rails_multisite/connection_management.rb:77:in with_connection' /var/www/discourse/app/jobs/base.rb:129:inblock in perform’
/var/www/discourse/app/jobs/base.rb:125:in each' /var/www/discourse/app/jobs/base.rb:125:inperform’
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/processor.rb:188:in execute_job' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/processor.rb:170:inblock (2 levels) in process’
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/middleware/chain.rb:128:in block in invoke' /var/www/discourse/lib/sidekiq/pausable.rb:80:incall’
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/middleware/chain.rb:130:in block in invoke' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/middleware/chain.rb:133:ininvoke’
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/processor.rb:169:in block in process' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/processor.rb:141:inblock (6 levels) in dispatch’
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/job_retry.rb:97:in local' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/processor.rb:140:inblock (5 levels) in dispatch’
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq.rb:36:in block in <module:Sidekiq>' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/processor.rb:136:inblock (4 levels) in dispatch’
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/processor.rb:204:in stats' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/processor.rb:131:inblock (3 levels) in dispatch’
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/job_logger.rb:7:in call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/processor.rb:130:inblock (2 levels) in dispatch’
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/job_retry.rb:72:in global' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/processor.rb:129:inblock in dispatch’
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/logging.rb:44:in with_context' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/logging.rb:38:inwith_job_hash_context’
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/processor.rb:128:in dispatch' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/processor.rb:168:inprocess’
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/processor.rb:85:in process_one' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/processor.rb:73:inrun’
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/util.rb:16:in watchdog' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/util.rb:25:inblock in safe_thread’
It looks like that URI is not resolving from your server. Can you ping that hostname? Can you curl the profile image from the server? From inside the Discourse container?
There isn’t a ‘ping’ in the production instance of Discourse but I have successfully curled a number of test images. On the server hosting the images I control, I’m not seeing an incoming connection.
That was my best guess. And you did curl them from inside the container? I just checked and curl is installed in the container, so
cd /var/discourse
./launcher enter app
curl THE_IMAGE_URI
If that’s what you did, I’m stumped.
The plot thickens with this… I had been trying PNG files and flipped to trying JPGs. The first worked. The second didn’t. The third did. It’s not an image size thing as far as I can tell, my max_image_size is set to 10Mb and these files are no where near this.
Looking through the code, I tried to run the guts of download_avatar_from_url as below:
tempfile = FileHelper.download("https://i.pinimg.com/originals/a0/58/a1/a058a111187bafdb88698b6408dedc7a.jpg", max_file_size: SiteSetting.max_image_size_kb.kilobytes, tmp_file_name: "sso-avatar", follow_redirect: true)
The above works.
[2] pry(main)> tempfile = FileHelper.download("http://paradipport.gov.in/Admin/images/login.png", max_file_size: SiteSetting.max_image_size_kb.kilobytes, tmp_file_name: "sso-avatar", follow_redirect: true)
OpenURI::HTTPError: 406 Error
from /var/www/discourse/lib/file_helper.rb:50:in `download'
[3] pry(main)>
The above does not. I’m at a loss.
