Avatar size problem
There are two avatars, the first is 174px at 250px (gif), the second 174px is at 250px (png), Gif - It is set fine, and png turns into a square
PNG - 174px 250px
GIF - 174px 250px
img.avatar {
        border-radius: 0%;
        width: 180px;
        max-height: 250px;
        height: auto;
I raise topic :roll_eyes:
Highly recommend that you learn CSS first. Here are a few useful links to get started
But the dimensions are the same
I’m fairly certain that the call at Size topic avatar, has an assumption for non-GIF files to be square, but that is purely a guess.
<script type="text/discourse-plugin" version="0.4">
    api.changeWidgetSetting('post-avatar', 'size', '180');
</script>
Right, I’m claiming that is likely what is forcing it to be a square for PNG. I’d have to dig into how avatars are created, but that would be my guess at this point.
It’s been a while since I uploaded an atypical avatar, but IIRC, there as some type of “will be cropped” message as well as the “may take a while” message.
