Avatar URLs and Custom Userfields
(Ron) #1
Hello,
I added a custom userfield called ‘externalid’ and I’d like to be able to use
" https://someexternalwebsite.com/image{externalid}.png "
for external system avatars url.
Doable?
(Jeff Atwood) #2
Is this for single sign on? There is a different mechanism for adding custom hidden user fields related to SSO only visible to the system (not to admins or the users). Isn’t there @sam?
(Ron) #3
It’s for incorporating already-created avatars for a gaming community.
(Ron) #4
I got things working by using the ruby client and posting data to the API.
You can POST whatever URL you’d like for the Avatar.
cheers
(Eddie One) #5
Hi, can you explain the solution more? We also could use the userid in ‘external system avatars url’ as we have an API for public user data.
(Ron) #6
In thinking this over more, SSO is probably the best path forward.
@EddieOne
The external system has a userid. Their portrait is located at an easy to form URL like
images.externalsite.com/character123456789_128.png
Where 123456789 is the userid on the externalsite not locally in the forum software.
