Avatars do not change for some users
(Tomek) #1
Hi, I’m having problems with only some users failing to update their avatars.
I’m using SSO to provide a new URL (that is a valid public URL) for a user. I’m using sync_sso to force the update (with avatar_force_update = true in the payload) and in same cases it works but in some cases it doesn’t.
I have this user:
https://forum.dobreprogramy.pl/u/krystian3w/summary
In his profile I see the SSO payload points to the new URL avatar:
http://avatarsb.dpcdn.pl/imgc/Avatar/530134/g_s_150x150_-_-_530134x20171108112511_u530134.png
However the avatar for this user is still old and nothing helps (waiting, cleaning cache, logging out etc).
How can I diagnose this problem?
(Joshua Rosenfeld) #2
This was fixed this a few versions ago, and I see you’re up to date on 1.9.0.beta14. @techAPJ, any chance we regressed here?
(Arpit Jalan) #3
I don’t think we’ve regressed here.
@TomekB is the site setting sso_overrides_avatar enabled? If not, can you enable the setting and ask user to logout/login again?
I would look at /logs for related errors.
(Tomek) #4
I have sso_overrider_avatar enabled and as I mentioned it works in most cases.
I don’t see anything in /logs, that was my first goto.
#5
Does it matter that his new avatar is not hosted on a secure site? http vs. https. How is his avatar otherwise different from the ones that do work?
(Tomek) #6
There are no obvious differences.
All avatars are hosted in the same place with https.
https://avatarsb.dpcdn.pl/imgc/Avatar/46340/g_s_150x150_-_-_46340x20171109124415_u46340.png
I even checked the format (jpg/png), size, weight, aspect…
Just enabled extended sso logging, nothing there.
Clearly the forum has a new avatar in the SSO payload (I see this in admin -> user), the file is fine, accessible but does not refresh.
(Tomek) #7
Nothing, no ideas?
Can you give me a hint how to diagnose this problem?
(Arpit Jalan) #8
I would look at user’s UserAvatar record to check updated_at, custom_upload_id and corresponding Upload record.
Honestly, this makes it tricky to debug the issue. Are there any similarities/pattern in user records for which avatar refresh is failing?
