Backup failed — whats to check?
The backup has failed.
Here’s the log:
[2017-12-19 10:59:34] [STARTED]
[2017-12-19 10:59:34] 'dmitre' has started the backup!
[2017-12-19 10:59:34] Marking backup as running...
[2017-12-19 10:59:34] Making sure '/var/www/discourse/tmp/backups/default/2017-12-19-105934' exists...
[2017-12-19 10:59:34] Making sure '/var/www/discourse/public/backups/default' exists...
[2017-12-19 10:59:34] Pausing sidekiq...
[2017-12-19 10:59:34] Waiting for sidekiq to finish running jobs...
[2017-12-19 10:59:34] Dumping the public schema of the database...
[2017-12-19 11:01:08] Finalizing backup...
[2017-12-19 11:01:08] Creating archive: da-stereo-2017-12-19-105934-v20171214040346.tar.gz
[2017-12-19 11:01:08] Making sure archive does not already exist...
[2017-12-19 11:01:08] Creating empty archive...
[2017-12-19 11:01:08] Archiving data dump...
[2017-12-19 11:01:09] Archiving uploads...
[2017-12-19 11:02:37] Removing tmp '/var/www/discourse/tmp/backups/default/2017-12-19-105934' directory...
[2017-12-19 11:02:37] Gzipping archive, this may take a while...
[2017-12-19 11:11:29] EXCEPTION: Failed to gzip archive.
gzip: /var/www/discourse/public/backups/default/da-stereo-2017-12-19-105934-v20171214040346.tar.gz: No space left on device
[2017-12-19 11:11:29] /var/www/discourse/lib/discourse.rb:27:in `execute_command'
/var/www/discourse/lib/backup_restore/backuper.rb:244:in `create_archive'
/var/www/discourse/lib/backup_restore/backuper.rb:42:in `run'
/var/www/discourse/lib/backup_restore/backup_restore.rb:163:in `block in start!'
/var/www/discourse/lib/backup_restore/backup_restore.rb:160:in `fork'
/var/www/discourse/lib/backup_restore/backup_restore.rb:160:in `start!'
/var/www/discourse/lib/backup_restore/backup_restore.rb:15:in `backup!'
/var/www/discourse/app/controllers/admin/backups_controller.rb:31:in `create'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/basic_implicit_render.rb:4:in `send_action'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/abstract_controller/base.rb:186:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/rendering.rb:30:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/abstract_controller/callbacks.rb:20:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/callbacks.rb:131:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/abstract_controller/callbacks.rb:19:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/rescue.rb:20:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/instrumentation.rb:32:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/notifications.rb:166:in `block in instrument'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/notifications/instrumenter.rb:21:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/notifications.rb:166:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/instrumentation.rb:30:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/params_wrapper.rb:252:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/railties/controller_runtime.rb:22:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/abstract_controller/base.rb:124:in `process'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionview-5.1.4/lib/action_view/rendering.rb:30:in `process'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-mini-profiler-0.10.7/lib/mini_profiler/profiling_methods.rb:102:in `block in profile_method'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal.rb:189:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal.rb:253:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/route_set.rb:49:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/route_set.rb:31:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/mapper.rb:16:in `block in <class:Constraints>'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/mapper.rb:46:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/journey/router.rb:50:in `block in serve'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/journey/router.rb:33:in `each'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/journey/router.rb:33:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/route_set.rb:834:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-protection-2.0.0/lib/rack/protection/frame_options.rb:31:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/omniauth-1.6.1/lib/omniauth/strategy.rb:189:in `call!'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/omniauth-1.6.1/lib/omniauth/strategy.rb:167:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/omniauth-1.6.1/lib/omniauth/builder.rb:63:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/conditional_get.rb:38:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/head.rb:12:in `call'
/var/www/discourse/lib/middleware/anonymous_cache.rb:149:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/session/abstract/id.rb:232:in `context'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/session/abstract/id.rb:226:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/cookies.rb:613:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/callbacks.rb:26:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/callbacks.rb:97:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/callbacks.rb:24:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/debug_exceptions.rb:59:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/show_exceptions.rb:31:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/logster-1.2.9/lib/logster/middleware/reporter.rb:31:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/rack/logger.rb:36:in `call_app'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/rack/logger.rb:26:in `call'
/var/www/discourse/config/initializers/100-quiet_logger.rb:16:in `call'
/var/www/discourse/config/initializers/100-silence_logger.rb:29:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/remote_ip.rb:79:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/request_id.rb:25:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/method_override.rb:22:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/runtime.rb:22:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/executor.rb:12:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/sendfile.rb:111:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-mini-profiler-0.10.7/lib/mini_profiler/profiler.rb:282:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/message_bus-2.1.1/lib/message_bus/rack/middleware.rb:63:in `call'
/var/www/discourse/lib/middleware/request_tracker.rb:138:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/engine.rb:522:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/railtie.rb:185:in `public_send'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/railtie.rb:185:in `method_missing'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/urlmap.rb:68:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/urlmap.rb:53:in `each'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/urlmap.rb:53:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.3.1/lib/unicorn/http_server.rb:606:in `process_client'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.3.1/lib/unicorn/http_server.rb:702:in `worker_loop'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.3.1/lib/unicorn/http_server.rb:549:in `spawn_missing_workers'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.3.1/lib/unicorn/http_server.rb:563:in `maintain_worker_count'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.3.1/lib/unicorn/http_server.rb:293:in `join'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.3.1/bin/unicorn:126:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.4.0/bin/unicorn:23:in `load'
/var/www/discourse/vendor/bundle/ruby/2.4.0/bin/unicorn:23:in `<main>'
[2017-12-19 11:11:29] Notifying 'dmitre' of the end of the backup...
I’m on DO server.
I’d first check the free space in the server.
  1. SSH into your server
  2. Enter this command: df -hP
@nixie is right :wink:
Here’s the important line
