Backup path changes
unsupported-install
(madhankumar) #1
Dear Team,
How can i change discourse default backup path, kindly advise.
(Jay Pfaffman) #2
What problem are you trying to solve? What’s wrong with where the backups are?
Maybe it’s a disk space issue? What you’d do is add a volume in app.yml to put the backups somewhere else on the host system.
(Andrew Schleifer) #3
That is not configurable. If you want to put the backups elsewhere, do as @pfaffman suggests and mount a volume under /var/www/discourse/public/backups in the docker container.
(Jeff Atwood) #7
bitnami install is not supported, follow the official setup guide
