Backup Showing No Progress
(charles) #1
Created new 1.7.0.beta3 install then go to /admin/backups then click on upload, select the test.tar.gz (1.8mb) file but the progress continue to show 0%
Should the percentage change even a bit or does it only change at 100%?
Waited for several minutes with no change.
edit: slow progress but it finally showed up
