Banner looks odd when logged in
#1
Hello guys!
I have the problem that when being logged in into the forum you cannot see the whole banner but it is cut at the right end. Is there someone who ran into this issue in the past? The thing is that this does not occur when not being logged in.
Thanks a lot for your help!
Jousef
(cpradio) #2
Are you sure that isn’t simply due to the width of the browser window?
As I just created an account there, and I see the same issue when I make my browser window smaller, when it is maximized, it looks fine. To me it seems your banner image only works when the browser is at least
Right now your CSS is using background-size: cover, I think you want
background-size: 100% auto (at least it solves the issue for me)
You could also attempt using background-size: contain, which works great on smaller windows, but isn’t great on larger desktops (lots of white space to the right)
#3
Thanks a lot for your response @cpradio!
Will see if the points you mentioned work and get back to you.
Cheers and thanks again!
Jousef
