Banner themes (and instructions for customizing them)
Well yes, when we are at home we have dinner at 8 - 8.30 PM, but at the restaurant we go at least at 9 - 9.30 PM often even later :fork_and_knife::blush:
PS. However remember to add the new icons in the site setting svg icon subset. I used the icons that Discourse already uses to make them work right away…
Hello
I have download a full width banner and add to my themes, picture below :
My question is : what is the way to change words and pics and add links, on css modify menu I have a white page like this :
How can I edit theca and html to modify and add my settings ?
Thank you
All banners have been updated to Fontawesome 5.
Texts are not on CSS but in the After Header tab.
Please note if you update the banner you will lose all the changes you made.
The best way is to fork the banner you want on Github and do the changes there
In order to edit the actual banner, if I just import the component as it is, I get a warning that my customization will be overwritten when the component updates. So I created a fork that I could customize. Is that the right thing to do?
For now yes, it is the smartest thing to do.
Thanks. This is an awesome component. Thank you for making it available.
Hello
Thank you for your answer
How can I practice the change on the banner on Github?
Best regards
Yves
After you’ve forked it, just click on the pencil icon at the top right to edit the HTML file with the new texts and elements. On CSS it is enough to change the variables at the beginning of the file
Excuse me, my english is poor…
What do you mean with : “After you’ve forked it”
I don’t find the translation in french.
Salut @Yves_Lauzin
On trouve un guide pratique à Forking Projects · GitHub Guides
Je dois l’apprendre, moi aussi! On peut s’aider en français si vous voulez, par des messages personnels.
Bonsoir
Ok no problem
Mon discourse est installé et je suis dans le relooking
2 posts were merged into an existing topic: Discourse Category Banners
hello @Dax
am trying to hide the banner for users using this code
.anon .section-header {
    display: block;
but not working still showing for the users, please advise.
It should be
.anon .banner-box {
    display:none;
Nothing Happening
am doing this:
.banner-box {
    display: none;
.anon .banner-box {
    display: block;
but its hiding it for both logged in users and guests
Why you are doing this?
You need only to add
.anon .banner-box {
    display:none;
to hide the banner for anon users
and not
As anon user:
As registered user:
I’ve tried to change the icon, but unfortunately, it does not work. What I’m doing wrong?
<div class="x-icon"><svg class="fa d-icon d-icon-user-shield svg-icon svg-node" aria-hidden="true"><use xlink:href="#user-shield"></use></svg></div>
Did you add the user-shield icon in the site setting svg icon subset?
Sorry ma’am i didn’t explain it well.
I want to hide it for the logged in users and show it for guests.
