Bash Script for Discourse Alpine Linux Install
Hi,
Hope you are well.
Has anyone got a bash script for installing and configuring Discourse?
I want to load Discourse onto Linode for 5 different people at the moment so automation would be welcome.
I plan to use Alpine Linux as the base image.
Thanks in advance
There is a very well supported standard install, which uses Ubuntu or whatever. You are gonna be hard pressed to find any support for Alpine if things get wonky, so I recommend just following the standard installation and try it out. It’s probably fine. :slight_smile:
You can pipe the input into discourse-setup. That’s whey my install script does. I recommend using Ubuntu or Debian as the server OS.
@pfaffman
Mind sharing your setup file and instructions?
Just follow the Discourse official Standard Installation guide. You can pipe in all of the stuff that you’d type.
