[beta] Topic Permalinks
(Benjamin Kampmann) #1
Heyah,
Attention: first draft!
I just finished the first (working) version of my permalink plugin. From the Readme:
Details
Through this plugin a topic can now have a permalink-custom_field for lookup that it can be found it.
The plugin operates in two modes: redirect and legacy-mode. When the permalink_redirect setting is set to true (default) in the Administration interface, the plugin will match the permalink and when found redirect to the new URL – this is recommended behaviour. If disabled however, the topic will be only accessible through that permalink and use that instead of the generated links.
.Attention: This plugin requires discourse >= 0.9.9.7 . Please upgrade to master.
This is particularly handy to be set when importing older systems and not wanting to lose the “SEO juice” of their pretty URLS.
Add UI for editing custom per-topic fields
