Better recognition for image URLs
(Alexandre Angelim) #1
Most of Rails applications append a query string on image URLs to manage versioning. I don’t know if this is common practice for other frameworks, but I’ve stumbled upon many sites using this approach.
When pasting(in the composer) an image url with a query string, discourse doesn’t seem to recognize it and leaves a link, instead. Can we parse the url taking that into account or is there another caveat I’m not considering?
(Jeff Atwood) #2
What you mean like this:
?foo=bar
Versus like this?
<img src='//discourse-meta.s3-us-west-1.amazonaws.com/original/2X/5/55a8020ac5d482a5f8c1aad218dcf8b42d6c4d0b.jpg'>
Most software on the Internet does expect image URLs to end in image filename extensions, so I don’t think this is a big deal.
(Kane York) #3
@codinghorror’s original post, before the system helpfully downloaded the images, editing his code block in the process:
https://www.google.com/logos/doodles/2014/percy-julians-115th-birthday-born-1899-5688801926053888-hp.jpg?foo=bar
Versus like this?
`https://www.google.com/logos/doodles/2014/percy-julians-115th-birthday-born-1899-5688801926053888-hp.jpg`
Most software on the Internet *does* expect image URLs to end in image filename extensions, so I don't think this is a big deal.
NB: The third link was oneboxed, the first was not.
(Alexandre Angelim) #4
Sorry. I should have given an example.
I mean like this:
(Sam Saffron) #5
Yeah, this would be a onebox bug, pull request? GitHub - discourse/onebox: A gem for turning URLs into website previews
(Jeff Atwood) #6
Could be a bug. Did it work that way (that is, ignore query strings) before? I can’t remember. Do you remember @eviltrout?
(Sam Saffron) #7
It’s a bug, don’t think it is a regression
EDIT
This may not be happening at the onebox level, not sure, need to read through the code
(Evaryont 🎆) #8
I think it is Onebox’s fault – it’s regex for the ImageEngine expects the URL to end with gif/jpg/png/etc, and doesn’t account for query parameters. I’ve got some code, but I’m working on some unit tests before I submit a pull request.
Edit: And now it’s done, opened a pull request.
https://github.com/discourse/onebox/pull/207
Edit #2: And once more, this time for audio/video URLs:
https://github.com/discourse/onebox/pull/205
(Robin Ward) #9
Thanks so much! I’ve pushed a new version of the gem and updated Discourse to depend on it. It’s available in master now and should be deployed to all our sites soonish.
(Jeff Atwood) #10
