Big tmp backup dir
(mbajur) #1
Hello,
recently i observed that one of the docker-discourse-related directories takes 6GB of space and i’m not sure what for. I’m basically having trouble with my hard-drive being out-of-space (it’s a 50 GB SSD) and am now trying to find a reason.
This 6GB directory is
/var/lib/docker/overlay2/d3efebc7ffea4a0aaea51f1b8c56358020ffa4be8d6cb6c59c49fcaa56f568aa/merged/var/www/discourse/tmp/backups/default
and all i can see in there are some old backup data files no longer needed. Is that normal? Can i just remove them? Is there any recommended way of clearing such caches? I don’t want to break something.
Thanks in advance.
(Jeff Atwood) #2
From the SSH command line
./launcher cleanup
(mbajur) #3
I’m affraid that didn’t helped. I still do have that big 10GB (it was 6GB when i was writing my original post, now it’s 10) backup folder in /var/lib/docker/overlay2 and the cleanup command says that
Finished Cleanup (bytes free 0)
