Blank page with js error after upgrade
javascript
(Jong Eun Lee) #1
I configurated multisite.
Before upgrading, it work properly.
After upgrading via admin/upgrade page, my discourse site shows only white blank page.
Only thing I know, there is a javascript error :
TypeError: undefined is not an object (evaluating 'Discourse.PageTracker.current')
./launcher rebuild web several times. Not helpful.
(Sam Saffron) #2
Which browser, can we access the site? Which locale, what’s in /logs
(Jong Eun Lee) #3
safari and chrome show same error. ko/kr locale…
chrome
Uncaught TypeError: Cannot read property 'current' of undefined
Did you mean /var/www/discourse/log in container?
There is no error. All requests are 200 OK
(Jong Eun Lee) #4
./launch logs web result :
run-parts: executing /etc/runit/1.d/00-ensure-links
run-parts: executing /etc/runit/1.d/anacron
run-parts: executing /etc/runit/1.d/cleanup-pids
Cleaning stale PID files
run-parts: executing /etc/runit/1.d/copy-env
run-parts: executing /etc/runit/1.d/ensure-web-nginx-read
Started runsvdir, PID is 34
rsyslogd: invalid or yet-unknown config file command 'KLogPermitNonKernelFacility' - have you forgotten to load a module? [try http://www.rsyslog.com/e/3003 ]
rsyslogd: warning: ~ action is deprecated, consider using the 'stop' statement instead [try http://www.rsyslog.com/e/2307 ]
Server listening on 0.0.0.0 port 22.
Server listening on :: port 22.
rsyslogd: Could no open output pipe '/dev/xconsole': No such file or directory [try http://www.rsyslog.com/e/2039 ]
supervisor pid: 42 unicorn pid: 58
Accepted publickey for root from 172.17.42.1 port 44784 ssh2: RSA 4c:f1:b9:d1:f4:05:fa:3b:e9:d2:9c:c3:a0:c2:c8:ff
Received disconnect from 172.17.42.1: 11: disconnected by user
Accepted publickey for root from 172.17.42.1 port 46106 ssh2: RSA 4c:f1:b9:d1:f4:05:fa:3b:e9:d2:9c:c3:a0:c2:c8:ff
root@discourse:/var/discourse# ./launcher logs web
(Jong Eun Lee) #5
I modified web.yml as below
params:
  version: latest-release
And run rebuild, it work properly.
beta works also.
Pagetracker is a new feature?
(Sam Saffron) #6
Page tracker is old, is it broken for tests-passed?
(Jong Eun Lee) #7
Yes, it is broken for tests-passed.
Beta works properly also.
(Ionuț Staicu) #8
Today update broke this functinoality: Discourse.PageTracker.current(); (thisis also missing on meta.discourse as well).
I used for small things, but i was able to use jquery's ready.
(Sam Saffron) #9
Ahh this must have been some es6 work @eviltrout did, can you paste in the consumer code you have?
(Robin Ward) #10
As we are going forward with ES6 modules I am removing constants like Discouse.XYZ in favor of importing the modules instead. I’ve been trying to put a deprecation notice in place but it’s hard to remember all the constants that people are using.
This commit adds a proper backwards compatible deprecation notice for PageTracker. You’ll want to update your code to import it instead.
https://github.com/discourse/discourse/commit/b587bc580f35be992329c5b0ff1f64abd2a8f28b
Script to enable Matomo analytics on Discourse
#11
Sorry I re-dump this topic but yesterday I upgrade discourse from “1.5.0.beta9” to "1.5.0.beta11" and now I’ve got the same “blank page” on my site :’(
I don’t have strange plugins on it.
Only:
  • Adsense
  • Tagging
  • Solved
At chrome’s console I have only 1 error:
Uncaught TypeError: Cannot read property 'current' of undefined pointing (?) to /assets/application-fc163a7681e31ca5970dd32b81b08fc9.js
What can I do?
(Sam Saffron) #12
Try without Adsense ?
#13
Well, I removed Adsense.
Now it works fine!
So “Adsense plugin” does not working fine with last version. Cc. @michaeld
Thanks @Sam !!!
(Michael - DiscourseHosting.com) #14
This is caused by the new Client API changes.
@eviltrout has updated the AdSense plugin now! :heart_eyes:
