Blank white page after launcher rebuild app due to IP access
Hello,
I had to update the SMTP address so updated the same in app.yml and did a “ ./launcher rebuild app”. As part of that it updated all the packages and upon completion I am only able to to a blank white page.
I followed the suggestion given here (Blank white page after update) to set the version to stable, still no change. Can you please let me know what I should check? Below are the trailing logs from the rebuild command.
> I, [2020-08-20T06:10:08.607786 #1]  INFO -- : Replacing (?-mix:location @discourse {) with location @discourse {
>   limit_conn connperip $conn_per_ip;
>   limit_req zone=flood burst=$burst_per_second nodelay;
>   limit_req zone=bot burst=$burst_per_minute nodelay; in /etc/nginx/conf.d/discourse.conf
> I, [2020-08-20T06:10:08.608166 #1]  INFO -- : > echo "Beginning of custom commands"
> I, [2020-08-20T06:10:08.610509 #1]  INFO -- : Beginning of custom commands
> I, [2020-08-20T06:10:08.610614 #1]  INFO -- : > echo "End of custom commands"
> I, [2020-08-20T06:10:08.612635 #1]  INFO -- : End of custom commands
> I, [2020-08-20T06:10:08.612700 #1]  INFO -- : Terminating async processes
> I, [2020-08-20T06:10:08.612731 #1]  INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/12/bin/postmaster -D /etc/postgresql/12/main pid: 52
> I, [2020-08-20T06:10:08.612779 #1]  INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 169
> 2020-08-20 06:10:08.612 UTC [52] LOG:  received fast shutdown request
> 169:signal-handler (1597903808) Received SIGTERM scheduling shutdown...
> 2020-08-20 06:10:08.613 UTC [52] LOG:  aborting any active transactions
> 2020-08-20 06:10:08.616 UTC [52] LOG:  background worker "logical replication launcher" (PID 61) exited with exit code 1
> 2020-08-20 06:10:08.616 UTC [56] LOG:  shutting down
> 169:M 20 Aug 2020 06:10:08.619 # User requested shutdown...
> 169:M 20 Aug 2020 06:10:08.619 * Saving the final RDB snapshot before exiting.
> 169:M 20 Aug 2020 06:10:08.626 * DB saved on disk
> 169:M 20 Aug 2020 06:10:08.626 # Redis is now ready to exit, bye bye...
> 2020-08-20 06:10:08.672 UTC [52] LOG:  database system is shut down
> sha256:e4251470b644b45283a690923f0af6e59431606d9d18aceba110f18f6d9505fe
> 84717a9f5e214562e8dc82e0687956664c63e6cf1e3426cc0e77d9ac75868fe0
> Removing old container
> + /usr/bin/docker rm app
> app
> + /usr/bin/docker run --shm-size=512m -d --restart=always -e LANG=en_US.UTF-8 -e RAILS_ENV=production -e UNICORN_WORKERS=8 -e UNICORN_SIDEKIQS=1 -e RUBY_GLOBAL_METHOD_CACHE_SIZE=131072 -e RUBY_GC_HEAP_GROWTH_MAX_SLOTS=40000 -e RUBY_GC_HEAP_INIT_SLOTS=400000 -e RUBY_GC_HEAP_OLDOBJECT_LIMIT_FACTOR=1.5 -e DISCOURSE_DB_SOCKET=/var/run/postgresql -e DISCOURSE_DB_HOST= -e DISCOURSE_DB_PORT= -e DISCOURSE_HOSTNAME=forum.xxxxxx -e DISCOURSE_DEVELOPER_EMAILS=xxxxxxxxx@xxxxxxxxx,xxxxxxxxxx@xxxxxxxxx -e DISCOURSE_SMTP_ADDRESS=smtp.xxxxxxxxxx -e DISCOURSE_SMTP_PORT=25 -e DISCOURSE_SMTP_USER_NAME= -e DISCOURSE_SMTP_PASSWORD= -h NSC-QC-app -e DOCKER_HOST_IP=172.18.0.1 --name app -t -p 80:80 -p 443:443 -v /var/discourse/shared/standalone:/shared -v /var/discourse/shared/standalone/log/var-log:/var/log --mac-address 02:1a:8e:9a:ec:3f local_discourse/app /sbin/boot
> 5925dc54b25648e07845933eea36ca31e9f141e4531195657c240e5799ceaaee
Logs from production.log:
> Started GET "/admin/site_settings/category/all_results?filter=mail" for 127.0.0.1 at 2020-08-20 06:58:03 +0000
> Processing by Admin::SiteSettingsController#index as HTML
>   Parameters: {"filter"=>"mail", "id"=>"all_results"}
>   Rendering default/empty.html.erb within layouts/application
>   Rendered default/empty.html.erb within layouts/application (Duration: 0.1ms | Allocations: 26)
>   Rendered layouts/_head.html.erb (Duration: 1.8ms | Allocations: 877)
>   Rendered common/_discourse_stylesheet.html.erb (Duration: 0.4ms | Allocations: 264)
>   Rendered application/_header.html.erb (Duration: 0.2ms | Allocations: 92)
> Completed 200 OK in 73ms (Views: 9.2ms | ActiveRecord: 0.0ms | Allocations: 33388)
Edit: If I use the curl command, then I can see the page being returned.
see errors in the browser console, maybe some js-code causes an error and the page does not load
Found that the issue exists only while accessing using IP. Since there are some ongoing network changes, didn’t have a valid DNS name to access. After finding one hostname that resolves, the page is now loading.
Is there any limitation that access can only be through hostname?
Yes, Discourse does not support being loaded at an IP address.
