Block users via API or other?
api
(Darren Reid) #1
Currently trying to maintain a list of users external to discourse which will update on a regular basis due to subscription status of each user.
I can see that you can update a users title, for example, via the API but trying to update ‘blocked’ by send a PUT request to /users/{username} doesn’t change anything. Also tried /admin/users/{usersname} but get a 404.
Use case is:
Want to block users who don’t have an active subscription.
Want discourse to manage user auth and management.
External list is updated daily.
Any tips/advice would be appreciated. Cheers!
(Kane York) #2
  1. Make a test account
  2. Go to suspend it with the message “subscription expired”
  3. Open browser developer tools, network panel
  4. Write down the request details
(Darren Reid) #3
Thanks for the tip. I common trick I’ve been using.
Not looking to suspend a user, but to block them. I’ll keep it in mind as an option. Thanks!
(Kane York) #4
What do you mean by “block” exactly? Prevent them from reading the site?
If your site is login_required, a suspension will prevent them from reading.
(Darren Reid) #5
Ahh apologies, I think I’ve misunderstood these two options on the user page.
Looking at this and what you have said, I think suspending a user makes most sense! Thanks again for your help!
