Blocked from setting up tags...?
(Blu McCormick) #1
Hello!
I am not able to set up tags here:
Here are my settings. I am a TL4 and Admin and therefore authorized to generate tags:
Does anyone have ideas as to why I am not permitted to generate tags?
#2
What happens when you try to create the tag group? Is there an error?
(Blu McCormick) #3
The save button is faded and there is a circle symbol with a line through it telling me that I am not permitted to do the function for some reason.
(Joshua Rosenfeld) #4
Did you add at least one tag to the group? I’d be surprised if we allowed the creation of empty tag groups.
(Blu McCormick) #5
Yes I did. I will do a video to show you in case I amdoing something wrong. I am assuming it’s me that is the problem. :laughing:
(Jeff Atwood) #6
What version of Discourse are you on? This feature has been changing quickly of late.
(Blu McCormick) #7
Wow. Thanks for all of the help, guys. Really appreciate it.
Here is the video:
Forgive me, figuring out where to see what version I have. Will post that in a sec.
(Joshua Rosenfeld) #8
I see it. You didn’t actually create the test tag. You need to click “Create: ‘test’”.
It should look like this once created (note the grey background and small “x”):
(Blu McCormick) #9
Goodness gracious. That simple. Thank you all. We are using tags to assign authors to blogs when it’s decided topic(s) are blog-ready.
(Joshua Rosenfeld) #10
This topic was automatically closed after 31 hours. New replies are no longer allowed.
