Blockquote CSS troubles with Markdown
#1
Hello again Discourse,
I’m trying to modify the look of quotes displayed on my forum to appear as simply a green text, since my users aren’t really used to blocky quotes.
What the problem is, is that I can only apply the style to a paragraph within the block quote, and the markdown editor treats a single line break as the same paragraph and only adds a <br>, probably by design. This means that the text right underneath a block quote also gets treated as part of the quote, which is incorrect behavior in my opinion. Here’s an example:
Without the CSS:
Adding a quotation mark before both lines doesn’t make a difference:
Now with the custom style:
My idea is to only turn the blockquote into simple green text while preserving the quotation mark as well, like on most imageboards. This is the style I’m using:
blockquote {
    border: 0;
    color: #789922;
    background: transparent;
blockquote p::before {
    content:'>';
    white-space: nowrap;
blockquote p::after {
    content: "\A";
  white-space: pre;
One solution could be, the editor makes a new paragraph after each line break (pressing enter) thus applying the style and the “before” content correctly.
Any help will be appreciated.
(Jeff Atwood) #2
Nope this is correct Markdown behavior. If you want a proper paragraph, they must have lines between them. See http://commonmark.org
#3
So absolutely no way I can change it? That’s a bummer. :frowning:
(Mittineague) #4
One thing that I can think of that would cause problems with automatically changing line breaks into paragraphs is when a new line should not be a new paragraph. eg. a list.
Not that it couldn’t be done, only that it wouldn’t be as simple as it may first appear to be. Hitting enter is simple enough, no?
#5
Does anyone have an idea which file I’d need to edit to make it work? Editing files in the app did not help, since they reset after rebuilding.
(Joshua Rosenfeld) #6
You’d need to make a plugin to have changes persist through rebuilds.
(Kane York) #7
Markdown is block-based, not line-based. Any method of doing what you want (per-line quotes) would be a massive overhaul of the text rendering process and break built-in text.
