Brew bundle is dead
(Theron Boerner) #1
The brew bundle command has been removed Discourse should either switch to a shell script or Brewdler
(Mike McQuaid) #2
For anyone following this thread: this is the new official replacement to brew bundle now: GitHub - Homebrew/homebrew-bundle: Bundler for non-Ruby dependencies from Homebrew
(Felix Niklas) #3
It’s great that there is a osx setup script – thanks for that!
I also had to deal with the deprecated brew bundle today:
$ script/osx_dev
Error: Unknown command: bundle
I fixed scripts/osx_dev:31 like this:
echo "Installing development dependencies from Brewfile..."
# Install brews
# ensure that Homebrew's sources are up to date
brew update
# add this repo to Homebrew's sources
brew tap homebrew/dupes
brew install $(cat Brewfile|grep -v "#")
and changed the Brewfile to this:
# Install development dependencies on Mac OS X using Homebrew (http://mxcl.github.com/homebrew)
# install the gcc compiler required for ruby
apple-gcc42
# you probably already have git installed; ensure that it is the latest version
git
# install the PostgreSQL database
postgresql
# install the Redis datastore
redis
# install headless Javascript testing library
phantomjs
