Broken Discourse
(Johnny) #1
Hi,
I recently was able to successfully install and view discourse on nginx proxy. But now discourse seems broken, e.g
Page Not Found
while trying to load /categories.json
I have attached the image, any help?
EDIT: I already tried “rebuilding” and “boostrapping” the app like tens of times. but same result.
(Rafael dos Santos Silva) #2
Do you really need a nginx proxy with Discourse? That’s an advanced setup. We really recomend sticking to the quick guide and running everything inside the container and using a DNS subdomain for the forums.
(Johnny) #3
Yes, I have multiple domains, each with different configuration, hence I don’t want discourse to run on its own nginx. But via proxy through external nginx.
(Vinoth Kannan) #4
Could you share your nginx configuration to know more? Are you using multiple discourse containers in same VM?
(Matt Palmer) #5
Something is misconfigured. Without knowing exactly what your configuration is, it’s a bit hard to be more specific than that.
(Johnny) #6
Hi the issue was revolved. Site works fine. @Falco thanks for suggesting subdomain. However, as I am using proxy. I followed digital ocean’s example, now when I try to register an account, it then for registration proceeds to port “25654”, (https://meta.domain.com:25654/…" which gives error. as this port won’t respond.
port 25654 isn’t forwarding to port 80 :confused:
digital ocean’s example:
my Nginx config file is below.
http://pastebin.com/dMQvyvRS
my app.yml:
http://pastebin.com/751jp5Zh
(Johnny) #7
Hi,
I got it working. everything is working fine now except images. Images are broken. I tried all the dir’s such as “$domain/public/images/discourse.png” | “$domain/images/discourse.png” …
but it says not found. Discourse is unable to find the image. Even if i give absolute path in the admin settings i.e “/var/www/discourse/images/discourse.png” it still gives 404 error.
P.S: I am using SSL.
