Broken Image In Posts?
(Clever Moniker) #1
So I know there is another topic on this, but the research I’ve done hasn’t solved the problem. :frowning:
I can upload an image, but once I leave he topic and come back, the image is broken.
I’m running off of DigitalOcean, installed using the official guide (NOT one-click install), and running off root domain (checked settings and everything seems correct).
Any ideas what might be going on?
Thanks so much,
CM
(Régis Hanol) #2
What are the URLs of the images when they’re broken?
#3
CleverMoniker here, I had to log in using a different moniker since Facebook gave me a “Check Point” when I logged in as CleverMoniker through Discourse. That was brutal.
Anyways, to explain what was going on… I was using a www. domain BUT Discourse was storing and displaying the images under non-www. I was unaware it even mattered…
All I did was reconfigure DigitalOcean’s domain to non-www and setup a nginx redirect. Now I see the images and we’re all good.
I’m confused as to why it even matters though?
(Régis Hanol) #4
http://your-domain.com is indeed not the same as http://www.your-domain.com.
If you misconfigured your Discourse (ie. used http://www. for your Discourse, but configured it with http://) then it’s normal all your images broke once Discourse has cooked the posts.
#5
I configured Discourse with no http:// or www, just… example.com.
DigitalOcean’s domain was setup “www” which linked to the ipaddress. I’d log in on www.example.com, post and image, and Discourse would cook it under the non-www. So basically yeah, you’re right. :slight_smile:
If I may, maybe a note should be made on the official install? Something like, “setup an nginx redirect after install etc.” as maybe others like me who a new to this wouldn’t know why their images were broken.
(Rafael dos Santos Silva) #6
A nginx redirect is not needed if the Discourse hostname is configured properly on app.yml.
#7
I understand.
All I’m saying here is, a new person like me will (most likely) view domains as “www” and will set up the DNS at DigitalOcean using it.
Discourse’s install clearly states:
Hostname for your Discourse? [discourse.example.com]: <-- most people here will copy the example and not place a www in front of the domain name.
Now they’ve kinda messed themselves without realizing it. All I’m saying is, you guys are all super knowledgeable and stuff, maybe a little bit of hand holding can help out the new people. :slight_smile:
