Bulk Actions: Remove tag from selected topics
I would like a “remove this tag from selected posts” bulk option in the tag management window. Right now I can replace the tags (which destroys all tags on the post) or add tags, but I can’t remove the tags.
Now, this dialogue is more general bulk actions, so it might be better to add this to the top of the tag’s page, to appear when you select topics within the screen. So When you select topics, something like this pops up:
Desired action will be to remove the tag from the selected topics.
Use case: As our community has never been able to use tags before, they’re just adding lots of the wrong tags to their posts. So I find myself needing to remove tags from selected posts. For now, I have to open each thread individually, edit the title, and then remove the tags, and save. NOT ideal, especially when dealing with dozens.
