Bulk/Multiple Redirects
Is there a way to implement multiple redirects at the same time, rather than update them one at a time? Wanting to cut down the amount of time I spend implementing redirects by doing them in bulk.
Do you mean permalink redirects? It might help to know about permalink normalizations. But if you have lots to create, then you want to do it at the rails console.
Can you say more about what you’re trying to do?
