Bypassing Site.Setting.login_required for external SSO
javascript
(cpk) #1
I am wondering if there is a way to bypass SiteSetting.login_required and return a sig and payload. I am implementing login via a mobile app against a discourse instance with SSO enabled.
I have a working plugin that returns the nonce instead of redirecting, to be used later in the flow upon login success against the primary site. Looks something like this
def return_nonce
	nonce = DiscourseSingleSignOn.generate_url(params[:return_path] || '/')
	uri_array = Rack::Utils.parse_query(nonce)
	render json: uri_array
This only works with login_required off. Could this be function be modified to work with that setting set to on? Thanks!
(Sam Saffron) #2
wait, are you saying sso is broken if login required is true?
(cpk) #3
@sam, no not at all. There is simply a server side redirect before the render returns. We found a fix on the front end. Thanks.
(Kane York) #4
The combination of login required + sso means that all pages redirect to the SSO url, which is what you’re seeing.
