Can a plugin break other plugins?
(Pad Pors) #1
perhaps it’s a strange question, but have you seen the requests of one plugin have conflicts with the codes of others; such that several plugins become disable because of that one?
(Rafael dos Santos Silva) #2
Yes, this already happened several times here on Meta.
(Pad Pors) #3
is there any rule of thumbs to follow, so that such situations are avoided as much as possible?
or perhaps a better question, how did you understand which plugin has caused the error?
(Rafael dos Santos Silva) #4
  • Don’t install random plugins on a production site
  • Have a staging environment with similar data from production where you can test before upgrading production
  • Only install plugins you need. There are several big and active discourse installs plugin free. Of course some instances need a bit of customization but that is a maintenance burden increase that you should be aware.
Read logs, F12 for JS and /logs for Ruby. The backtrace will tell you where the error is 99% of the time.
