Can add support like QA system?
(Sanwu-three) #1
Hi guys.
I want a QA system in my bbs like this.
Some point:
  1. Need to know which question is "Unanswered " and which is “Answred” . List is best way to show .
  2. Who post the quest .who manager it`s .()
that all
like this : https://answers.unrealengine.com/
(Louis Rossouw) #2
You have the Solved plugin already. I think it’s installed by default (edit or not). You just need to edit the category settings to activate it in a category. You can see it in operation in this category:
The ones with the tick are solved:
E.g.:
(Jeff Atwood) #3
You’re right, but the Solved plugin is not installed by default, unless you are on our hosting plans.
