Can Discourse be implemented in an ASPX application?
#1
If yes, does anyone have a link to an example of one? Thanks!
(Sigurður Guðbrandsson) #2
Only as an iFrame or a reverse proxy if you’re clever enough.
(Robin Ward) #3
It’s better to not think of Discourse as something you “embed” in another app. It works best as an application you link to from your app. I’d suggest having a link that says “Forum” or “Community” and then have that go to your Discourse.
