Can I edit /etc/hosts?
(Gergely Fazekas) #1
I think I figured out what the problem is on my installation - I adjusted the server’s /etc/hosts file, so the smtp server resolves to the internal IP instead of the public one, however that goes to hell because the same setting isn’t in the container’s /etc/hosts file.
How can I echo the setting while bootstrapping? Because if I ssh into the container, obviously /etc/hosts is on a read-only filesystem.
(Jonathan Feist) #2
Try (stab in the dark here) adding something like echo '127.0.0.1 localhost.com' >> /etc/hosts to line 63 by sudo nano -c +63 /var/docker/containers/app.yml replacing:
- exec: echo "Beginning of custom commands" with
- exec: echo "echo '127.0.0.1 localhost.com' >> /etc/hosts"
(Gergely Fazekas) #3
Thanks for the suggestion!
Unfortunately that didn’t do the trick. And I’m almost 100% sure this would solve my email troubles.
(Kane York) #4
Er, remove the first echo. And have correct YAML syntax.
- exec: "echo '127.0.0.1 localhost.com' >> /etc/hosts"
(Gergely Fazekas) #5
(): did not find expected key while parsing a block mapping at line 9 column 1
YAML syntax error. Please check your configuration files.
If I have the first echo as per @def’s suggestion, bootstrapping goes through (without effect though)
(Gergely Fazekas) #6
I managed to edit the file, buy switching to root with sudo su and editing /var/lib/docker/containers/CONTAINER-ID/hosts
It’s a pretty ugly hack, and not persistent, but at least fixes the problem I’ve been having.
(Sam Saffron) #7
We now have runit which does a custom init process, you would hook changes to hosts or resolve and any other protected files there.
(Avinash Singh) #8
You cannot edit /etc/hosts file but you can copy it somewhere else and then make changes in
LD_LIBRARY_PATH and point that hosts file which you copied and then edit it.Please refer to the following link
http://www.dev2ops.in/setting-up-puppet-agents-in-docker-containers/
(Gergely Fazekas) #9
Thanks! This is useful, as I’m deploying Discourse on GreenQloud VMs and our network setup messes a bit with the internal/public IPs
